Show offline APs with instant cluster?
  • 1.  Show offline APs with instant cluster?
    Posted Apr 15, 2017 05:41 AM
    I have a IAP cluster with around 25 APs. Everything is working great. However some times accesspoints go down for various resons, power outage, bad poe-adapter, bad cabling or it gets accidentaly unplugged.
    When this happens it disappears from the instant web admin interface. Is there any way to keep down/offline aps in the list, even if they are down, or some other way of easily seeing missing or down aps?
  • 2.  RE: Show offline APs with instant cluster?
    MVP EXPERT
    Posted Apr 15, 2017 07:59 AM
    Hey, you can determine the up/down state of the IAP cluster with Airwave. It is not visible in the IAP GUI or CLI. This will show you all the info. Failing that you could configure a syslog server and then have a external application to alert you when a specific snmp trap is seen.
  • 3.  RE: Show offline APs with instant cluster?
    Posted Apr 17, 2017 04:06 AM
    Please check the Alert section under monitoring tab on Instant UI to see if it helps.
