Network Management
shutdown airwave
  • 1.  shutdown airwave
    Posted Mar 22, 2018 09:46 AM
    Whtas the difference between
    shutdown -h now
    and
    shutdown -p now
    i think both just shutdown the airwave but whtas the diference?
    Cheers
    Carlos
  • 2.  RE: shutdown airwave
    MVP EXPERT
    Posted Mar 22, 2018 12:35 PM
    Hey, I believe they should be the same as the Linux/Unix commands:
    -h will halt after shutdown and terminates all processes and shuts down the cpu.
    -p is poweroff and is exactly like halt, but it also turns off the unit itself (lights and everything on a PC). It sends an ACPI command to the board, then to the PSU, to cut the power.
    Is the AirWave running on CentOS?
  • 3.  RE: shutdown airwave
    Posted Mar 22, 2018 01:46 PM
    Yes, airwave runs on cent os
    My question would be if i wanted to shutdown the airwave which of the two i shoudl use?
    I think i have tried both and both seems to do the same but well which one would be recommended?
    Cheers
    Carlos
  • 4.  RE: shutdown airwave
    Posted Mar 23, 2018 04:55 AM
    As mentioned both works same only differnece is -p poweroff the lights aswell.
    If you want to complete remove the server from network and want to ship to different place then use poweroff, else halt is fine.
  • 5.  RE: shutdown airwave
    Posted Mar 23, 2018 08:37 AM
    Okay
    Well i got a virtual server of airwave, and we are doing a maintenience to the physical server so we need to turn it off.
    In thi case halt(shutdown -h now) is fine? or do i need to poweroff(shudown -p now)?
    Cheers
    Carlos
  • 6.  RE: shutdown airwave
    Posted Mar 23, 2018 10:27 AM
    ACPI in the BIOS should already be enabled.  So halt and poweroff should be doing the same thing.  You could also call the shutdown from the AMPCLI: Advanced (8) -> Shutdown (6)
    AirWave Management Platform 8.2.6 on airwave.lab.com
    1 Upload File
    2 Download File
    3 Delete File
    4 Backup
    5 Restore
    6 Support
    7 Upgrade
    8 Advanced
    9 Security
    10 Custom Commands
    11 Enter Commands
    q >> Quit
    Your choice: 8
    Advanced
    1 Restart Application
    2 Reboot System
    3 Configure Network Settings
    4 Set Hostname
    5 Set Timezone
    ***6 Shutdown System (halt)***
    7 Add the File Transfer User
    b >> Back
    This uses /sbin/halt which results in complete power off.
  • 7.  RE: shutdown airwave
    Posted Mar 23, 2018 11:25 AM
    its the same on airwave pre 8.2.4?
    Cheers
    Carlos
  • 8.  RE: shutdown airwave
    Posted Mar 23, 2018 11:38 AM
    The AMPCLI cmd is introduced in 8.2.4.  If you're on an earlier version, both shutdown -h and shutdown -p should do the same thing.  ACPI has been around for a while, so the server should be performing the full shutdown at this point unless the hardware is 10yrs or older.
