Signal Slow and High Utilization
  • 1.  Signal Slow and High Utilization
    Posted Aug 05, 2017 10:55 AM
    We have an issue where our Client are in Low Signal Strange and using Very high Utilization.
    Each AP properly place far from each other.
  • 2.  RE: Signal Slow and High Utilization
    Posted Aug 05, 2017 01:41 PM
    What is the min and max transmit power for 2.4ghz under the ARM settings?  You probably have to lower the max for your 2.4ghz band.
  • 3.  RE: Signal Slow and High Utilization
    Posted Aug 05, 2017 09:25 PM
    Hi Colin,
    I have attach two screen show
    1. Current Default,
    So base on your recommendatino i need to tick cusotmize and if so which number should i put for Max?
  • 4.  RE: Signal Slow and High Utilization
    Posted Aug 06, 2017 09:03 AM
    Change the min and max to 12,
