SD-WAN
  • 1.  Silver Peak for Closed Govt network
    Posted Feb 04, 2024 10:23 PM
    Hi everyone,
    Do we have an option to deploy Silver Peak SD WAN in a closed network ( with no internet connection at all ) ?
    Thanks !!
  • 2.  RE: Silver Peak for Closed Govt network
    Posted Feb 05, 2024 02:34 AM
    You can run the Aruba Orchestrator on prem, so it's possible to run the solution in an airgapped environment.
    Arne Opdal
  • 3.  RE: Silver Peak for Closed Govt network
    Posted Feb 06, 2024 02:40 AM
    Air-gapped is on the roadmap, as far as I know. Having an on-premises orchestrator doesn't necessarily mean it's air-gapped, as it needs to connect to the cloud portal via the internet for licensing and other purposes. I would recommend waiting a bit longer, and it would be best to talk to the HPE local account manager for more information.
  • 4.  RE: Silver Peak for Closed Govt network
    Posted Feb 06, 2024 10:51 AM
    That's correct. AirGap mode for the on-prem Orchestrator is arriving in release 9.4.2. It allows completely Internet disconnected EdgeConnect fabric. The Orch and EdgeConnect appliances never need to touch the Internet, even during install.
    -AP
