Developer
Silverpeak Orchestrator ip whitelist failure
  • 1.  Silverpeak Orchestrator ip whitelist failure
    Posted Apr 01, 2024 11:42 AM
    I have created an API Key and whitelisted it to 10.0.0.0/8
    When I run my code I get:
    "024-03-28 12:44:07,587 - orch_burnsmcd-orch-use1.silverpeak.cloud - ERROR - [GET] /gmsserver/briefInfo | Received HTTP 401 | Response text: IP address is not in API Key whitelist: 10.255.35.26"
    Wouldn't that address be in the allowed whitelist?
  • 2.  RE: Silverpeak Orchestrator ip whitelist failure
    Posted Apr 03, 2024 06:07 AM
    jjjones2@burnsmcd.com" data-itemmentionkey="f3363b6c-7a2c-4d3b-bfb7-076747ab5b37" biobubblekey="mention74662d4f-552a-4708-8f9e-63830c163709" href="https://community.arubanetworks.com/profile?UserKey=74662d4f-552a-4708-8f9e-63830c163709" data-can-remove="False">@jjjones2@burnsmcd.com - it's a valid mask and looks correct. Please contact TAC support for assistance and they will get you the help you need for this question. Another suggestion would be to test a smaller subnet and see of the /8 is causing the issue.
