Simultaneous Login Limit for Guest Network in Instant
  • 1.  Simultaneous Login Limit for Guest Network in Instant
    Posted Mar 14, 2018 11:03 AM
    Hi experts,
    Yesterday I have a trial in customer with a cluster of Instant. Customer wanted to try the captive portal included in IAPs, but we realized when you create a guest user for the guest network there is no a simultaneous login limit for that users (unlike Aruba Central), many users can connect with that user at the same time. Then:
    1. Is there any option in Instant to limit the simultaneous logins for the same user?
    2. Because I found no option I tried to solve the problem by using MAC authentication, and tie the MAC addresses with the guest users created. Is this possible?
    Julián
  • 2.  RE: Simultaneous Login Limit for Guest Network in Instant
    Posted Mar 14, 2018 06:24 PM
    Hi guys,
    Any ideas? Isn't this possible?
    Julián
  • 3.  RE: Simultaneous Login Limit for Guest Network in Instant
    Posted Mar 16, 2018 10:06 AM
    ClearPass.
  • 4.  RE: Simultaneous Login Limit for Guest Network in Instant
    Posted Mar 16, 2018 10:17 AM
    Or Aruba Central, little bit dissapointed with Aruba Instant...
    Julián
