Simultaneous Telnet connections to my Aruba Mobility Controller
  • 1.  Simultaneous Telnet connections to my Aruba Mobility Controller
    Posted Nov 23, 2011 04:46 PM
    Hi !
    I would like to increase the number of simultaneous Telnet connections allowed to my Aruba Mobility Controller : ArubaOS 5.0.3.3
    User concerned is "admin" with "root" role.
    Any idea how i can do that ?
    Thanks for all and best reagards,
  • 2.  RE: Simultaneous Telnet connections to my Aruba Mobility Controller
    Posted Nov 23, 2011 05:19 PM
    That cannot be increased, unfortunately.
    You can type "show loginsession" to see who is currently logged in.  You can also type, from the console "clear loginsession <x>" to disconnect that user, but only when you are connected to the physical console.
  • 3.  RE: Simultaneous Telnet connections to my Aruba Mobility Controller
    Posted Nov 23, 2011 06:50 PM
    well...ok...
    Do you know what is, officially, the max simultaneous connections allowed on telnet port, by default ?
    In my tests it seems this is 4-5-6...not really sure...
    Note Answer : i've improved my script : this is 5 simultaneous telnet connections.
    Regards
  • 4.  RE: Simultaneous Telnet connections to my Aruba Mobility Controller
    Posted Nov 23, 2011 09:38 PM
    5 is the max number of concurrent telnet session.  Keep in mind to set the "loginsession timeout" to a reasonable time.
    In other words, if you set the loginsession timeout to 0 (infinite) and then you inadvertently close the ssh session abruptly, you may put yourself in a bind ..
