Thank you for that hint, Rikard!
After reading your thread, I've "diff"ed the script location from P06 and P10. I've found two changes that cause problems.
One problem appears in file <IMC>/server/conf/adapters/ICC/Cisco/CiscoIOSGeneric/enter_enable.tcl, which was changed like this:
old file | new file
# If the user can't login to enable, try to succe|# If the user can't login to enable, try to succe
if { $execAccessOnly == "true" } { |if { $execAccessOnly == "true" } {
set enable_prompt $exec_prompt | set enable_prompt $exec_prompt
} else { |} else {
-------------------------------------------------| expect {
-------------------------------------------------| $exec_prompt {
send "enable\r" | send "enable\r"
set loop true | set loop true
if {$useTruePrompt != "false"} { | if {$useTruePrompt != "false"} {
send "\r" | send "\r"
expect -re "\[\r\n\]+(.*?$enable_prompt)"| expect -re "\[\r\n\]+(.*?$enable_prompt)"
set enable_prompt $expect_out(1,string) | set enable_prompt $expect_out(1,string)
After restoring the old file on the server, the backups work again on almost all Cisco devices.
There were addinional problems concerning Nexus 7010 routers, which got fixed using the previous version of <IMC>/server/conf/adapters/ICC/Cisco/CiscoIOSGeneric/initialize.tcl
Thank you for help! :)
