Since upgrade, Instant Config UI was disabled - caused delete of IAP config
  • 1.  Since upgrade, Instant Config UI was disabled - caused delete of IAP config
    Posted Mar 03, 2016 08:49 AM
    We upgraded last week to 8.0.11 AMP version. After upgrade for every group we manage the IAP's - the Instant Config GUI was disabled.
    So we Enabled the Instant Config GUI for every group, and then since sync was done - the Instant Config was gone at every VC for the groups we managed, so no SSID's where present.
    We had to manually add networks again so our customers could work again wireless.
    Is this a bug in 8.0.11?
  • 2.  RE: Since upgrade, Instant Config UI was disabled - caused delete of IAP config
    Posted Mar 03, 2016 08:56 AM
    We would have to know your exact steps to understand exactly what happened. You might want to open a case with TAC so they can see what steps you took and understand what led to your issue.
