Single antenna on MIMO AP
  • 1.  Single antenna on MIMO AP
    Posted Oct 08, 2012 07:32 AM
    can I install MIMO AP just with one antenna? I heard when antenas have nonoverlaping coverage bad things may happen..
    Typicall usecase: I need wireless bridge between two buildings it makes huge price difference to have two patch pannels or four patch pannels.
          V.D.
  • 2.  RE: Single antenna on MIMO AP
    Posted Oct 08, 2012 07:46 AM
    @v.dvorak wrote:
          V.D.
    Yes you can.  If the Mimo antenna has a dual connector, you should be fine.  The "overlapping coverage"  warning is for a single-connector antenna.
  • 3.  RE: Single antenna on MIMO AP
    Posted Oct 08, 2012 09:01 AM
    OK, and now I want to use single-connector antenna - do I need to disable HT on this AP or how should I do it safely?
