Single Click Captive Portal?
  • 1.  Single Click Captive Portal?
    Posted Mar 08, 2013 08:52 AM
    For special events I now have a separate SSID / AP group that does not require authentication or encryption.
    If I wanted to add a single click through CP like hospitals and hotels have where you have to at least glance at the disclaimer and then click the button before you can surf, how would I set that up? And also not screw up our standing CP login authentication for our other SSID.
    Thanks ahead of time!!
  • 2.  RE: Single Click Captive Portal?
    Posted Mar 08, 2013 10:09 AM
    Start Here:
    http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/Captive_Portal.php
    Then Go there here:
    http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-How-to-customize-the-Captive-Portal/td-p/15012
    Here is a full HTML ready script for one time button (read all the post - and than download the needed files)
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Captive-Portal-Login-page-quot-Login-in-1-Click-quot-template/m-p/61172/highlight/true#M7230
    *I also attached a great PDF'S regarding your question.
    have a lovely day.
    me
    BTW:
    Another good post that might give u an idea - from where and how to start:
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/HTTP-Script/td-p/13483
    Attachment(s)
    pdf
    aos_guestacccess-appnote.pdf   3.34 MB 1 version
    pdf
    customize-captive-portal.pdf   736 KB 1 version
    pdf
    cp_lang_custom_v11.pdf   882 KB 1 version
  • 3.  RE: Single Click Captive Portal?
    Posted Mar 08, 2013 10:51 AM
    Awesomeness!! Thanks Kdisc!!!
  • 4.  RE: Single Click Captive Portal?
    Posted Mar 08, 2013 10:53 AM
    Review the HTML example in https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-154.   It has a "single click"  "Accept" button setup; shown below.
