Single ssid with multiple psk passwords
  • 1.  Single ssid with multiple psk passwords
    Posted Sep 01, 2015 12:11 PM
    Is it possible to create multiple psk aes key/passphrases for 1 ssid? I currently have a secured wifi network that uses mac/password authentication only IT has the passphrase for and now I might have to give it out - would really rather not do that and would like to set up a new passphrase for just this one office.
    Any thoughts?
    Thanks!
    Gerri
  • 2.  RE: Single ssid with multiple psk passwords
    Posted Sep 01, 2015 12:13 PM
    No, this is not possible.
    Tim
  • 3.  RE: Single ssid with multiple psk passwords
    Posted Sep 01, 2015 12:50 PM
    OK - I was afraid of that but just had to ask.
    Thank you
    Gerri
  • 4.  RE: Single ssid with multiple psk passwords
    Posted Sep 01, 2015 12:52 PM
    Why not just do two SSIDs? One for your IT approved devices and the other with a PSK that you can give out?
  • 5.  RE: Single ssid with multiple psk passwords
    Posted Sep 01, 2015 12:42 PM
    Do you want to use different PSK for authentication at any one specific location (AP) ? if so you can use AP specific config option.
    Let me know if you need some help on this.
  • 6.  RE: Single ssid with multiple psk passwords
    Posted Sep 01, 2015 12:49 PM
    Sounds interesting - but I can see that might be problematic down the road - Guess I'll just have to give them the password dang it.
    Thanks!
    Gerri
  • 7.  RE: Single ssid with multiple psk passwords
    Posted Sep 01, 2015 12:56 PM
    It's a possibity - and then assign it to just them - we'll see what is gong to be best.
    Thanks!
