Single SSID with multiple VLANs
This thread has been viewed 21 times
  • 1.  Single SSID with multiple VLANs
    Posted May 01, 2016 10:30 PM
    Can we input multiple VLANs per SSID, in Virtual AP under AP Configuration so that we can use only 1 single SSID for the whole company and transfer the user to the designated VLAN based on the User Role with Role VLAN ID?
  • 2.  RE: Single SSID with multiple VLANs
    Posted May 01, 2016 10:33 PM
    Yes, you can return a VLAN assignment in your RADIUS response or assign VLANs to user roles and then return the user role.
    You do not have to add all the VLANs to the virtual-ap.
  • 3.  RE: Single SSID with multiple VLANs
    Posted May 01, 2016 10:41 PM
    Hi Cappalli,
    Thanks for your response. The authentication is MAC address using internal database. You mean we have to create a Radius Server (NPS) for this one?
    I have tried creating an account in the USER-ROLE with ROLE VLAN ID = 10 and bind it to the role in the internal database. But the user still getting the VLAN 20 which is indicated on the Virtual-AP once it connects.
  • 4.  RE: Single SSID with multiple VLANs
    Posted May 01, 2016 10:44 PM
    Yes, you could use the internal database but it is not very flexible.
    Are you clearing the user out of the user-table each time you test?
