SIP and H.323 ALG not used by default
  • 1.  SIP and H.323 ALG not used by default
    Posted Apr 05, 2017 07:44 PM
    The netservices for SIP and H.323 do not use their corresponding ALGs by default on the controller even though stateful firewall processing is enabled for both. Why is this? Is there any harm in enabling these ALGs? Would a maintenance window be required?
    We are on 6.4.4.11.
  • 2.  RE: SIP and H.323 ALG not used by default
    Posted Apr 05, 2017 08:28 PM
    I believe they are enabled by default. You just need to add the netservice to your user ACL and you should be good.
  • 3.  RE: SIP and H.323 ALG not used by default
    Posted Apr 05, 2017 10:24 PM
    Check out the highlighted items below. This is the default on the controller and has been since at least as long as I knew what an ALG actually is. The H.323 and TCP/UDP SIP netservices do not use their ALG out of the box, unlike other voice protocols like such as SCCP, SIPS, and Vocera:
    netservice svc-ipp-tcp tcp 631
    netservice svc-dhcp udp 67 68 alg dhcp
    netservice svc-citrix tcp 2598
    netservice svc-pcoip-udp udp 50002
    netservice svc-netbios-ssn tcp 139
    netservice svc-tftp udp 69 alg tftp
    netservice svc-papi udp 8211
    netservice svc-ica tcp 1494
    netservice svc-natt udp 4500
    netservice svc-lpd tcp 515
    netservice svc-microsoft-ds tcp 445
    netservice svc-syslog udp 514
    netservice svc-msrpc-tcp tcp 135 139
    netservice svc-msrpc-udp udp 135 139
    netservice svc-smtp tcp 25
    netservice svc-http-proxy2 tcp 8080
    netservice svc-cfgm-tcp tcp 8211
    netservice vnc tcp 5900 5905
    netservice svc-web tcp list "80 443"
    netservice svc-h323-udp udp 1718 1719
    netservice svc-sccp tcp 2000 alg sccp
    netservice svc-http tcp 80
    netservice svc-bootp udp 67 69
    netservice svc-telnet tcp 23
    netservice svc-vmware-rdp tcp 3389
    netservice svc-ipp-udp udp 631
    netservice svc-noe-oxo udp 5000 alg noe
    netservice svc-vocera udp 5002 alg vocera
    netservice svc-esp 50
    netservice svc-http-proxy1 tcp 3128
    netservice svc-sec-papi udp 8209
    netservice svc-l2tp udp 1701
    netservice svc-rtsp tcp 554 alg rtsp
    netservice svc-gre 47
    netservice svc-sip-tcp tcp 5060
    netservice svc-pptp tcp 1723
    netservice svc-snmp udp 161
    netservice svc-svp 119 alg svp
    netservice svc-icmp 1
    netservice svc-smb-tcp tcp 445
    netservice svc-pcoip2-tcp tcp 4172
    netservice svc-v6-icmp 58
    netservice svc-ssh tcp 22
    netservice svc-h323-tcp tcp 1720
    netservice svc-ntp udp 123
    netservice svc-pop3 tcp 110
    netservice svc-netbios-ns udp 137
    netservice svc-adp udp 8200
    netservice svc-v6-dhcp udp 546 547
    netservice svc-dns udp 53 alg dns
    netservice svc-netbios-dgm udp 138
    netservice svc-http-proxy3 tcp 8888
    netservice svc-sip-udp udp 5060
    netservice svc-kerberos udp 88
    netservice svc-sips tcp 5061 alg sips
    netservice svc-pcoip2-udp udp 4172
    netservice svc-pcoip-tcp tcp 50002
    netservice svc-noe udp 32512 alg noe
    netservice svc-nterm tcp 1026 1028
    netservice svc-ike udp 500
    netservice svc-snmp-trap udp 162
    netservice svc-https tcp 443
    netservice svc-smb-udp udp 445
    netservice svc-ftp tcp 21 alg ftp
  • 4.  RE: SIP and H.323 ALG not used by default
    Posted Apr 06, 2017 06:36 AM
    Are you saying that when you apply the netservice to a user role, the ALG is not applied? I am trying to understand what is not happening "out the box".
  • 5.  RE: SIP and H.323 ALG not used by default
    Posted Apr 06, 2017 02:48 PM
    The SIP and H.323 netservices are applied to the voice role by default; it's not about applying it to a role at all.
    Compare these default configuration netservices...
    ...to other default configuration netservices...
    See how the other voice netservices have their ALG turned on, but SIP and H.323 don't? This is default configuration.
    So back to my original question, would it be service impacting to turn on these ALGs on their respective netservices?
    And furthermore, why aren't they turned on by default out of the box?
  • 6.  RE: SIP and H.323 ALG not used by default
    Posted Apr 11, 2017 03:02 PM
    Any thoughts on this cjoseph?
  • 7.  RE: SIP and H.323 ALG not used by default
    Posted Apr 11, 2017 03:12 PM
    I don't now the answer to that general question.  It would be easier for me to find out what you are trying to do and help you with that specifically.
  • 8.  RE: SIP and H.323 ALG not used by default
    Posted Apr 11, 2017 03:59 PM
    Given: The SIP/H.323 ALG are turned off
    Question: What would the service impact be to turning them on?
    Given: Other voice ALGs are on by default
    Question: Why are the SIP/H.323 ALG off by default?
  • 9.  RE: SIP and H.323 ALG not used by default
    Posted Apr 11, 2017 04:08 PM
    Let me ask the first question a different way.
    We use both SIP and H.323 in our environment. Intuitively, it seems like we would benefit from having these ALGs turned on for the automatic prioritization. So, if we turned them on, is there risk? Or is overall performance going to be reduced?
    As for my second question, I am simply trying to find out why they aren't on by default. It seems that by being off by default, Aruba is implicitly saying that turning these ALGs on could cause an issue.
  • 10.  RE: SIP and H.323 ALG not used by default
    Posted Apr 11, 2017 04:10 PM
    Good question.  Let's see if we can find someone knows the answer...
  • 11.  RE: SIP and H.323 ALG not used by default
    Posted Apr 11, 2017 05:02 PM
    It would seem that there are many interpretations of "H323".  Every vendor had a different implementation.  We only correctly interpreted and supported Avaya's version, unfortunately.  That is probably why it is turned off by default.
