Site connection Failure - IPV6 issue
  • 1.  Site connection Failure - IPV6 issue
    Posted Nov 13, 2012 11:16 AM
    I have a problem when connecting to www.google.com mainly that the page does not connect.
    All other sites that i try will connect fine, both http and HTTPS.
    I notice that there is a IPv6 address for www.google.com on an NSLOOKUP
    Non-authoritative answer:
    Addresses:  2a00:1450:400c:c06::93
              74.125.132.147
              74.125.132.104
              74.125.132.105
              74.125.132.103
              74.125.132.106
              74.125.132.99
    Is there a way to disable the IPv6 lookup??
  • 2.  RE: Site connection Failure - IPV6 issue
    Posted Nov 13, 2012 06:55 PM
    Can you turn it off on the client?
  • 3.  RE: Site connection Failure - IPV6 issue
    Posted Nov 14, 2012 04:00 AM
    IP V6 is not enabled on the client, as in the box is unchecked.
  • 4.  RE: Site connection Failure - IPV6 issue
    Posted Nov 14, 2012 04:03 AM
    I'm apologize.
    What client is this?
  • 5.  RE: Site connection Failure - IPV6 issue
    Posted Nov 14, 2012 08:31 AM
    Windows 7, i have since found out www.wikipedia.org also has a ipv6 lookup via nslookup
    This also doest not connect,but some time it does very strange.
