Site-Site VPN in AOS 6.1.2.5
  • 1.  Site-Site VPN in AOS 6.1.2.5
    Posted Jan 06, 2012 10:57 AM
    Hello all,
    I was successful configured S-S VPN between 2400 and 3400 AOS 5 using this configuration, but for AOS 6 between 620 and 3400 controllers, the tunnel could not establish.  I knew 4500 UPD is working, because RAPs are working and using the same tunnel.  Here are my configurations:
    At master:
    (BTCWC03) #show datapath session table 66.37.244.77
           Q - Real-Time Quality analysis
           E - Media Deep Inspect, G - media signal
      Source IP     Destination IP  Prot SPort DPort  Cntr Prio ToS Age Destination TAge Flags
    66.37.244.77    172.18.254.96   17   4500  4500   0/0     0 0   4   local       41   FY
    172.18.254.96   66.37.244.77    17   4500  4500   0/0     0 0   0   local       41   FC
    #show crypto-local ipsec-map MASTER2SITE
    Crypto Map Template"MASTER2SITE" 100
             IKE Version: 1
             lifetime: [300 - 86400] seconds, no volume limit
             PFS (Y/N): N
             Transform sets={ *DEFAULT-TRANSFORM* }
             Peer gateway: 66.37.244.77
             Interface: VLAN 1
             Source network: 172.18.0.0/255.255.0.0
             Destination network: 172.16.18.0/255.255.255.0
             Pre-Connect (Y/N): Y
             Tunnel Trusted (Y/N): Y
             Forced NAT-T (Y/N): N (tried with both Y and N)
    At site:
    Crypto Map Template"SITE2MASTER" 100
             IKE Version: 1
             PFS (Y/N): N
             Peer gateway: 192.188.142.132 (this address NAT to master IP address)
             Interface: VLAN 10
             Source network: 172.16.18.0/255.255.255.0
             Destination network: 172.18.0.0/255.255.0.0
    Thank you for your help!
    Trinh Nguyen
    #3400
  • 2.  RE: Site-Site VPN in AOS 6.1.2.5
    Posted Jan 06, 2012 11:27 AM
    Use force NAT-T on both sides, otherwise the tunnel will require ports besides UDP 4500.
    Pre-Connect desides which side will establish the tunnel and you should have it only on one side for now so that it is deterministic.
    Use "show crypto ipsec sa" to see if there is a security association between those two sides.  If not, we have to do debugging on the security logs to find out how the tunnel gets established and why it does not get setup.
  • 3.  RE: Site-Site VPN in AOS 6.1.2.5
    Posted Jan 06, 2012 02:49 PM
    Thanks for your response Colin, but still no tunnel.
    I compared the configuration with known working AOS 5 site-site VPN, they are identical.  I remembered when I first setup AOS 6, I could not get the RAP tunnel to work, so I opened a case with support, he had to add this line to ip access-list session “control”, and RAP took off immediately.
     10        any     any          udp 8209      permit      Low
     Any more suggestions or ideas?  What is the best debug for VPN?
    Trinh Nguyen
  • 4.  RE: Site-Site VPN in AOS 6.1.2.5
    Posted Jan 06, 2012 02:54 PM
    Port 8209 is only used for APs... so that will not work here.
    All I can say that make sure that the VLAN is the VLAN of the Egress interface of the controller.
    Turn on debugging:
    config t
    logging level debug security process l2tp
    logging level debug security process crypto
    logging level debug security subcat vpn
    logging level debug security subcat IKE
    Then, while it is connecting, do a "show log security 50"
  • 5.  RE: Site-Site VPN in AOS 6.1.2.5
    Posted Jan 06, 2012 04:10 PM
    Don't ask me why it work, and here are how I did it: deleted both ipsec-local maps at master and site controllers, rebuilt the new maps with different names, and different ipsec-map-number.  Problem solved just like that!
  • 6.  RE: Site-Site VPN in AOS 6.1.2.5
    Posted Jan 06, 2012 04:29 PM
    Glad to hear it!
