Site-to-Site VPN - Peer ip 0.0.0.0 ignored
  • 1.  Site-to-Site VPN - Peer ip 0.0.0.0 ignored
    MVP
    Posted Mar 03, 2017 11:04 AM
    Good afternoon,
    I'm trying to setup a VPN tunnel between (2) controllers via site-to-site VPN configuration. The configuration we are using is as follows:
    Main Site
    crypto-local isakmp key "******" fqdn-any
    crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
    crypto-local ipsec-map dyn-sts 100
      peer-ip 0.0.0.0
      peer-fqdn any-fqdn
      vlan 0
      src-net 10.68.128.0 255.255.252.0
      dst-net 10.68.208.0 255.255.255.0
      set transform-set "default-transform"
      pre-connect enable
      trusted enable
      force-natt enable
    Remote Site
    crypto-local isakmp key "******" address 155.75.135.10 netmask 255.255.255.255
      peer-ip 155.75.135.10
      local-fqdn 100
      vlan 0
      src-net 10.68.208.0 255.255.255.0
      dst-net 10.68.128.0 255.255.252.0
      pre-connect enable
      trusted enable
      force-natt enable
    In logs we see IKEv1 attempts, but on the Main controllers, we are seeing the following message:
    Ignoring map dyn-sts since Peer-ip is 0.0.0.0
    We are using a dynamic IP at the remote site, so we can't specify an IP. Any ideas why we are receiving this or any ideas what we could be missing?
    Thanks.
    FYI - the remote controller is running 6.4.4.6 and has no licenses as of right now. My other thought is, the reason for the VPN tunnel is to route traffic and share networks, but is it accomplishing the same thing by just setting up master/local setup and setting next hop for those internal networks as the master controller? Would that traffic go through the IPSec tunnel assuming the local controller is gateway at remote site?
  • 2.  RE: Site-to-Site VPN - Peer ip 0.0.0.0 ignored
    Posted Mar 06, 2017 02:22 PM
    Is VLAN 0 the vlan of the interface facing the public IP?  If not I think it needs to be.
