Site to Site w/ Dynamic IP - Design & Advice
  • 1.  Site to Site w/ Dynamic IP - Design & Advice
    Posted Sep 09, 2014 11:04 PM
    I realize that site-to-site VPN is possible with one controller having a dynamic IP, however I'm looking for any advice or recommendations on how I might chose a controller and/or configure this before ordering equipment.
    My scenario is this: Site A has an existing 620 local running 6.1.3.6-Airgroup & Site B has a 620 master running the same AOS. I will be implementing some new AP's at site A which are not compatible with AOS 6.1.X so I'm looking at using a new 7005 running 6.4 code. Site A does NOT have a static public IP while site B DOES. My plan is to make the 7005 at site A a standalone master & then create a site-to-site VPN back to site B's master. This would allow for the same type of L3 routing that we already have with the master-local IPSEC tunnels.
    I'm open to any thoughts, suggestions. Thanks in advance.
    #7005
  • 2.  RE: Site to Site w/ Dynamic IP - Design & Advice
    Posted Sep 11, 2014 11:09 AM
    Bump. Any thoughts or suggestions?
  • 3.  RE: Site to Site w/ Dynamic IP - Design & Advice
    Posted Sep 14, 2014 09:47 AM
    Clayman,
    Is your question about if you should use the 7005 to terminate a site to site VPN using dynamic ip addresses?
  • 4.  RE: Site to Site w/ Dynamic IP - Design & Advice
    Posted Sep 15, 2014 03:43 PM
    My question is, does anyone see any reason why this would not work or if there are any "gotcha's" with tryin to do a site-to-site between a 7005 & a 620. The 7005 would have a dynamic public IP while the 620 would be static.
