SiteSurvey IAP-225 without Eth.Link
  • 1.  SiteSurvey IAP-225 without Eth.Link
    Posted Feb 28, 2014 08:25 AM
    last time by Sitesurvey with IAP225 i find out, that IAP need always Ethernet Link. Only with Poe enjector without Eth.Link IAP225 did not work.
    I connected a switch to Poe and could begin with my Sitesurvey by custumers.
    My question : It's possible without Eth.Link used IAP225?
  • 2.  RE: SiteSurvey IAP-225 without Eth.Link
    Posted Feb 28, 2014 08:45 AM
    You should be able to do this if you eneable the setting "Can be used without uplink" on the Advanced section of the WLAN settings for that network.
  • 3.  RE: SiteSurvey IAP-225 without Eth.Link
    Posted Feb 28, 2014 09:44 AM
    Thanks that worked!!!
