This thread has been viewed 28 times
  • 1.  SLB-mode
    Posted Oct 17, 2016 03:24 AM
    What are the operational details of the "channel and radio based" mode - there is no explanation in the guides of how this mode operates.
  • 2.  RE: SLB-mode
    Posted Oct 17, 2016 03:52 AM
    This feature, Spectrum Load Balancing is supposed to
    - Group access points into "Neighborhoods"
    - Load Balance Clients among those groupings either by radio or number of clients.
    Spectrum Load Balancing has been replaced by Client Match in Instant 4.2.x.x
  • 3.  RE: SLB-mode
    Posted Oct 24, 2016 05:23 AM
    Thanks for the information cjoseph.
  • 4.  RE: SLB-mode
    Posted Nov 24, 2016 09:14 AM
    Well, on 6.4.4.8-4.2.4.3 (ED) these commands are still present.
    And this is what interests me.
    We can configure a ClientMatch client threshold which is a 'Number of clients associated to each radio before the SLB algorithm kicks in' with default 30 clients per radio.
    arm
       client-match client-thresh {threshold}
    and then we have possibility to configure SLB mode, under Client-Match commands in ARM profile
       client-match slb-mode {1:Channel based; 2:Radio based; 3:Channel+Radio}
    Are those (SLB) settings not used for client load-balancing by ClientMatch feature on Instant?
  • 5.  RE: SLB-mode
    Posted Nov 24, 2016 09:44 AM
    Spectrum Load Balancing is an integrated configuraton component of Client Match.  In the past, it was separate.
  • 6.  RE: SLB-mode
    Posted Nov 24, 2016 10:40 AM
    Ok, thanks.
    So is:
    arm
    the same setting as CM threshold in GUI?
    Sorry to be such a pain in the ... but just want to be sure, because descriptions for both suggest these two configure different things.
    For example:
    For CLI: When the number of clients on a radio exceeds the value, SLB algorithm will be triggered.
    For GUI: acceptance client count difference among all the channels of Client match into account.
  • 7.  RE: SLB-mode
    Posted Nov 24, 2016 12:51 PM
    So, there are some ARM ClientMatch tuning parameters that can only be changed in the CLI (7 of them), instead of the GUI on Instant .  You will find those additional commands along with the descriptions in the CLI Guide here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=22480 starting on page 39.
    EDIT:  To directly answer your question, the "CM Threshold" in the GUI corresponds to the "calc-threshold" commandline parameter.
    The GUI of the controller also ONLY has a few CM commands in the GUI (with the rest being on the commandline).
