Slow speeds over IPSEC/GRE tunnel
  • 1.  Slow speeds over IPSEC/GRE tunnel
    Posted Oct 01, 2014 01:29 PM
    I have two 650 controllers that have an IPsec tunnel connecting them  with a GRE inside the IPSEC to provide a bridged VLAN.  When I try to do a speed test without using the vlan associated with the tunnel i get 30Mbs up and down.  When I use the tunnel i get 20Mbps up and only 3Mbps down.   Something seems to be significantly slowing down the traffic.  I am not sure if it is with the GRE or the IPSec tunnel
    Tunnel 199 is up line protocol is up
    Description: Tunnel Interface
    Source  10.24.242.1
    Destination 10.30.42.19
    Tunnel mtu is set to 1200
    Tunnel is a Layer2 GRE TUNNEL
    Tunnel is Trusted
    Inter Tunnel Flooding is enabled
    Tunnel keepalive is disabled
    tunnel vlan 33
    Source  10.30.42.19
    Destination 10.24.242.1
    Tunnel is Trusted
    Keepalive type is Default
    tunnel vlan 33
  • 2.  RE: Slow speeds over IPSEC/GRE tunnel
    Posted Oct 01, 2014 08:16 PM
    There is definitely overhead, whether it be encapsulation or serialization when doing GRE through IPSEC.  The MTU also might play a part as well (try increasing it on both sides).
    Other things you can try:
    - Disable Inter-tunnel flooding on both sides
    - Enable BCMC Optimization on on VLAN 33 on both controllers.
  • 3.  RE: Slow speeds over IPSEC/GRE tunnel
    Posted Oct 02, 2014 10:46 AM
    Thanks Colin,
    a slow down from 30Mbps to 3 is normal?  I am thinking it must be a duplex mismatch along the way somewhere.  I have alot of success with RAPs do they useally have that kind of preformance hit? what do they do differnetly then IPSEC with GRE?
  • 4.  RE: Slow speeds over IPSEC/GRE tunnel
    Posted Oct 02, 2014 10:49 AM
    mattjhughes,
    I did not say normal.  I am just giving you ideas on what to check, in addition to what you came up with, as well.
  • 5.  RE: Slow speeds over IPSEC/GRE tunnel
    Posted Oct 02, 2014 11:02 AM
    ok gotcha,  I will keep looking, I turned off tunnel-flooding, and have BCMC on. I have tweaked MTU but not sure how to go about picking the numbers I tried 1100, 1200, 1500.
  • 6.  RE: Slow speeds over IPSEC/GRE tunnel
    Posted Oct 02, 2014 11:08 AM
    Well,
    You should try to see what the TOP MTU is in the first place.  Increase the MTU and use the instructions on the page here:  http://samdobs.blogspot.com/2012/12/setting-df-bit-from-windows-machine.html to see when it fails.  Ideally you would ping a site that is outside of your network to test maximum MTU end-to-end or some site inside your network to test MTU for internal apps.
    The only other answer is to do a wireshark packet capture on the client to see what could be happening.  You might also require a packet capture on the near end and someone to interpret what it all means.  It could really be anywhere.
  • 7.  RE: Slow speeds over IPSEC/GRE tunnel
    Posted May 11, 2016 06:18 AM
    I have the exact same problem. In my case the probles started after 3 years. GRE layer 2 tunnel between 650 and 3500 controllers. From 650 to 3200 I get almost line speed (100 Mbps) and from 3200 to 650 3 Mbps. I have other tunnel that is working fine on the same VLAN. That is also between 650 and 3500 controllers. Strange.
  • 8.  RE: Slow speeds over IPSEC/GRE tunnel
    Posted Jun 06, 2016 02:41 AM
    I finally got this fixed. It was all about the MTU. Dropped it down from 1500 to 1200 and speeds are up again. Mayde my broadband provider changed something to make my MTU 1500 fail.
  • 9.  RE: Slow speeds over IPSEC/GRE tunnel
    Posted Apr 06, 2018 11:54 AM
    Do you recall how you adjusted the MTU on the IPSec tunnel?  Did you use the "Crypto Ipsec MTU" global command or did you adjust the GRE tunnel MTU?
