Slow Speeds RAP-109
  • 1.  Slow Speeds RAP-109
    Posted Sep 15, 2018 05:55 PM
    Received 4 RAP-109 units from work (off-lease) so I set up them up for my home. The units work well for coverage, roaming etc but the speed is terrible. I am running a near default config but I cannot break 80MBS on 5GZ N network.
    All RAP-109'S are POE connected to a 1GB switch. Config is attached. Please let me know what I can try. I imagine there is a default setting I need to tune.
    Also, important environmental factor to note.. I live in a house with no other wifi networks saturating the airwaves.
    Thanks in advance.
    Attachment(s)
    txt
    backup.txt   3 KB 1 version
  • 2.  RE: Slow Speeds RAP-109
    Posted Sep 15, 2018 10:21 PM
    Make sure pretty fly for a wifi also has broadcast filtering enabled
  • 3.  RE: Slow Speeds RAP-109
    Posted Sep 15, 2018 10:28 PM
    Thanks, I'll check. Is there other items I can check to increase speed based on the config?
    Thank You,
    Dan
    No trees were killed to send this message, but a large number of electrons were terribly inconvenienced
    ¨¨°¨Ô¨°¨¨
