Smartphone block with clearpass
  • 1.  Smartphone block with clearpass
    Posted Apr 02, 2017 01:20 PM
    It is possible to just block smartphones from the wifi with clearpass?
    I know you can block like all androids and stuff like that but i dont want to block tablets... just smartphones and thats it.
    Is that possible?
    If its how you can do that?
    Cheers
    Carlos
  • 2.  RE: Smartphone block with clearpass
    Posted Apr 02, 2017 02:35 PM
    It won't be very accurate since the OS is shared across the devices. You can try using IF-MAP profile data but it can be easily spoofed.
  • 3.  RE: Smartphone block with clearpass
    Posted Apr 02, 2017 03:12 PM
    so even with the ifmap it wont be really accurate???
    So is really not possible to do that?
    Cheers
    CArlos
  • 4.  RE: Smartphone block with clearpass
    Posted Apr 02, 2017 03:32 PM
    Not all devices pass their name in a user agent so it will be hit or miss.
    Just curious why you’d want to block one and not the other? They’re literally the same devices, just different sizes.
  • 5.  RE: Smartphone block with clearpass
    Posted Apr 02, 2017 04:47 PM
    There is a clietn which want to allow laptops and tablets but they dont want to allow smartphones
