smarty coded CPG operator filter
  • 1.  smarty coded CPG operator filter
    Posted Mar 12, 2020 07:49 AM
    I am already using "user acount filter" to make my guest operators see only but the accounts that match an static value of a field. For example, address=0. But I am trying to make it more adaptable so my operators get to see only those accounts that share their very same address.
    To acomplish that I included the attribute address as %{GuestUser:address} on the operator login service at CPPM, so I get populated on CPG the entry $smarty.session.userauth_user.address with the right value.
    But it does not work to use it like I would on a HTML header of any form. I typed it like this:
    address={$smarty.session.userauth_user.address}
    At this point the operator filter is not set to see all accounts coming from wider operators or even admin created accounts that match their address. But still nothing shows up.
    I also tried without brackets unsuccessfully.
    So the question is: can we use dynamic filters on "user account filters"?
    Or probably should be: how can I filter all accounts on the same address as the operator?
    Thanks you very much for your help and patience reading my post.
    J.A.
  • 2.  RE: smarty coded CPG operator filter
    Posted Mar 12, 2020 07:59 AM
    You can send dynamic attributes for the filter using the Enforcement profile for the operator:
    Is it an acceptable solution for that?
  • 3.  RE: smarty coded CPG operator filter
    Posted Mar 12, 2020 08:01 AM
    Yes! I will try it ASAP.
  • 4.  RE: smarty coded CPG operator filter
    Posted Mar 12, 2020 08:07 AM
    It works like a charm! Thank you very much, Mr.
    Is there a list of such attributes I can use? This particular one was not listed on the dropdown box when configuring the enforcement and it is not on any place I could read on the CPG docs.
  • 5.  RE: smarty coded CPG operator filter
    Posted Mar 12, 2020 08:09 AM
    You can define any attributes, also you can modify the "Guest User Repository" Source if you need to fetch another one.
  • 6.  RE: smarty coded CPG operator filter
    Posted Mar 12, 2020 08:19 AM
    Appologies for my wording. I meant attributes such as "filter_useraccount" and "admin_privileges" on the enforcement profile at CPPM.
