  • 1.  SMS Authentication Clearpass Guest
    Posted Nov 08, 2023 10:30 AM
    I would like to know if it was possible to authenticate with SMS on Clearpass.
    For example :
    1. A user arrive on a web page when connecting to the open wifi.
    2. A form ask the user his phone number.
    3. When he submit his phone number, a code is sent on his phone.
    4. A new form ask him the code.
    5. And then he is authenticated and has internet access.
    Have you ideas about this method ?
  • 2.  RE: SMS Authentication Clearpass Guest
    Posted Nov 08, 2023 11:32 AM
    Yes. Video.
    Just note that some (IOS) devices suffer the issue that when you open your SMS application, you can't get back to the captive portal.
  • 3.  RE: SMS Authentication Clearpass Guest
    Posted Nov 09, 2023 04:51 AM
    Thank you, it works now. But I have a question. In the video, at the end the user is not redirected to the portal. Do you know how can I change the redirection of the receipt page ?
  • 4.  RE: SMS Authentication Clearpass Guest
    Posted Nov 09, 2023 05:57 AM
    It depends a bit on what equipment is used, controller, Instant AP, AOS10, switch (and type/brand).
    But if the question is about an automatic redirect from the receipt page to the login page, then there are examples with javascript to do such an automatic redirect.
    If it is about redirecting to your own website, regardless of what triggered the initial redirect, then some access methods allow override of the URL, or you can do it in the NAS Vendor Settings in your Self Registration Workflow:
  • 5.  RE: SMS Authentication Clearpass Guest
    Posted Nov 09, 2023 06:59 AM
    Yes it is about an automatic redirect from receipt to login page. Where can I change the redirect with javascript ?
  • 6.  RE: SMS Authentication Clearpass Guest
    Posted Nov 09, 2023 08:10 AM
    Check this post, more specific the 'Auto Submit'.
