SMS gateway integration
  • 1.  SMS gateway integration
    Posted Aug 14, 2012 03:37 AM
    Hi All.
    We have guest access system with clear pass. How we can integrate with SMS gateway to obtain access code over sms ? . Please share any documents which explain this services and pre requisites .
    Shafi.
  • 2.  RE: SMS gateway integration
    Posted Aug 14, 2012 04:38 AM
    Hello Shafi,
    you should check chapter about SMS Services in the Clearpass Guest Deployment Guide. That should have the info you need to proceed.
    That said - I'm using the "Custom HTTP Handler" using HTTP GET when configuring SMS gateway for our customers. It's the easiest to setup and most gateway suppliers support this.
