SMS Guest receipt
  • 1.  SMS Guest receipt
    Posted Mar 25, 2018 03:20 PM
    Hello, in clearpass Guest self register mode, is there any possibility to send the credentials for the guest user into the sms receipt in an url format, that will allow the user to login to the network by clicking to this url, instead of to have to redirect to the login page and then introduce the credentials in user and password format?
    Thanks and regards
  • 2.  RE: SMS Guest receipt
    Posted Apr 21, 2018 06:51 AM
    Yes, you can do this by edit the SMS Receipt template
    Username: {$u.username|escape}
    Password: {$u.password|escape}
    {if $u.expire_time > 0}Expires: {$u.expire_time|nwadateformat:"iso-8601"|escape}{/if}
    make sure you are connected to the <SSID name> wifi network then click the below link:
    https://<FQDN>/guest/<Register page name>_login.php.php?username={$u.username|rawurlencode}&password={$u.password|rawurlencode}"
    and then when the user receive the SMS he can just click this link and he will be login automatically.
    regards
    Mahmoud Refaat
    Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
  • 3.  RE: SMS Guest receipt
    Posted Apr 21, 2018 01:41 PM
    Thanks a lot , i will try it on customer and let you know.
    Regards
    Enviado desde movil Huawei
    Manuel Aradilla
    Consulting & Professional Services Engineer
    T: +34 91 330 94 08
    M: +34 609 207 913
    E: Manuel.Aradilla@dimensiondata.com
    Calle Méndez Álvaro, 56 – Edificio Arnaiz Madrid, Madrid, 28045, Spain.
    For more information, please go to dimensiondata.com
    This email and all contents are subject to the following disclaimer:
    "http://www.dimensiondata.com/emaildisclaimer"
