SN reported in Association Requests
  • 1.  SN reported in Association Requests
    Posted Feb 07, 2014 10:02 AM
    Looking at a user debug, I see there is an SN noted in each association request in parenthesis with a numerical value, is that an SNR value, or something else?
    thanks, Dave
    Example:
      Assoc request @ 01:23:21.750767: 00:0b:28:06:3a:06 (SN 98): AP 10.16.201.60-d8:c7:c8:1f:c1:20-8P-10-East3-W
  • 2.  RE: SN reported in Association Requests
    Posted Feb 07, 2014 01:45 PM
    Taking a guess that looks more like channel noise which usually is around those values
  • 3.  RE: SN reported in Association Requests
    Posted Feb 07, 2014 01:47 PM
    Victor the values I am seeing in my example range from 5 to 226, but in other peoples logs I see values into 2000.  I havent been able to find the documentation that tells me just what SN is indicating.
  • 4.  RE: SN reported in Association Requests
    Posted Feb 07, 2014 01:52 PM
    I'm way off then
  • 5.  RE: SN reported in Association Requests
    Posted Feb 07, 2014 01:58 PM
    Sequence Number
  • 6.  RE: SN reported in Association Requests
    Posted Feb 07, 2014 02:03 PM
    Thank you Sir, so completely unrelated to Signal strength or Noise or any rating of the association.
  • 7.  RE: SN reported in Association Requests
    Posted Feb 07, 2014 02:05 PM
    Correct. If you have an OTA packet capture you would see it in the association request frame.
