SNMP aruba cluster
  • 1.  SNMP aruba cluster
    Posted Apr 03, 2012 10:49 AM
    Hi
    I have 2 aruba controllers on master redundancy mode and i want to set SNMP on the active master so that in case one master is down and the other takes over the snmp will still work with the new active master. Is there a way to this?? or is the snmp set per controller?
    /carlos
  • 2.  RE: SNMP aruba cluster
    Posted Apr 03, 2012 01:01 PM
    I have the same configuration (master redundancy) and i set snmp per controller. I think this is the way
  • 3.  RE: SNMP aruba cluster
    Posted Apr 03, 2012 01:10 PM
    Yes. The snmp configuration is local to the controller. You have to configure snmp individually on each controller.
