SNMP get users by AP
  • 1.  SNMP get users by AP
    Posted Nov 20, 2017 06:31 AM
    I want to get the number of users by AP in snmp, but find nothing like this in mibs. My controler is a 7210 with  6.4.4.16_61809 version.
  • 2.  RE: SNMP get users by AP
    Posted Nov 20, 2017 08:38 PM
    get the mibs (aruba and standard) for your release, put them in a directory. Install Net-SNMP (ensure you have a working snmpwalk and snmptable)
    Assumptions: community is "public", controller is "1.2.3.4", snmp community is set on the controller. Below examples are tested on linux, they will mostly work (except for maybe anything with  grep and awk in it) on windows if you install net-snmp for windows.
    Finally, please do note that a user is not the same as an association, since a single mac address is actually able to create 4 x IPv4 and 2 x IPv6 users in the user table (e.g. a dual stack client would create 2 entries in the user table, but one in the station table)
    1. dump all the stats for AP in table form, one of the columns is wlanAPNumClients
    snmptable -v2c -c public -M. -mALL -O0X 1.2.3.4 wlsxWlanAPStatsTable
    2. just get the wlanAPNumClients for all APs
    root@kali-246:/home/mibs/6.5.4.3# snmpwalk -v2c -c public -M. -mALL -O0X 1.2.3.4 wlanAPNumClients
    WLSX-WLAN-MIB::wlanAPNumClients[STRING: ac:a3:1e:c5:1e:f4][1][STRING: ac:a3:1e:d1:ef:50] = INTEGER: 1
    WLSX-WLAN-MIB::wlanAPNumClients[STRING: ac:a3:1e:c5:1e:f4][1][STRING: ac:a3:1e:d1:ef:51] = INTEGER: 0
    WLSX-WLAN-MIB::wlanAPNumClients[STRING: ac:a3:1e:c5:1e:f4][1][STRING: ac:a3:1e:d1:ef:52] = INTEGER: 0
    WLSX-WLAN-MIB::wlanAPNumClients[STRING: c8:b5:ad:ce:94:0e][1][STRING: c8:b5:ad:69:40:f0] = INTEGER: 2
    for option 2, you need to resolve the wired mac (first mac above) or  BSSIDs back to AP names (second mac above)
    e.g. for
    it is AP named 'ap315'
    root@kali-246:/home/mibs/6.5.4.3# snmpwalk -v2c -c public -M. -mALL -O0X 1.2.3.4 wlanAPName | grep c8:b5:ad:ce:94:0e
    WLSX-WLAN-MIB::wlanAPName[STRING: c8:b5:ad:ce:94:0e] = STRING: ap315
    the above method is the least load on the controller because you are interogating the AP table, but it requires a little more juggling to get the actual AP name (there are various other tables you can use to achieve the same). You need to take the output from wlanAPNumClients and split it up to get a pairing of like ap-wired-mac:num_clients and then resolve the mac. This would be easy to do with perl or python to postprocess the snmpwalk output of the two commands.
    Alternatively, if users are what you want, you can get them - but in a less friendly way to the controller as the user table is usually much longer than the AP tables
    snmpwalk -v2c -c public -M. -mALL -O0X 1.2.3.4 nUserApLocation
    which has output like this:
    WLSX-USER-MIB::nUserApLocation[STRING: 80:00:0b:45:2e:ff][192.168.1.5] = STRING: ap315
    WLSX-USER-MIB::nUserApLocation[STRING: e8:50:8b:0d:68:0d][192.168.1.17] = STRING: ap315
    WLSX-USER-MIB::nUserApLocation[STRING: f4:5c:89:97:d2:43][192.168.1.3] = STRING: ap215
    WLSX-USER-MIB::nUserApLocation[STRING: f4:5c:89:97:d2:43][192.168.1.4] = STRING: ap215
    which can be split up and counted using some more CLI type hackery (note that I have changed the output flag to -Ov to just get the value)
    snmpwalk -v2c -c public -M. -mALL -Ov 1.2.3.4 nUserApLocation 2>&1 | grep STRING | awk '{print $2}' | uniq -c
          2 ap315
          2 ap215
    you may note that above i had a value of 3 from wlanAPNumClients but the above is showing 2 + 2, that is because one of my clients has consumed a second IP and thus a second user.
