SNMP - Help with MIB to monitor the clients of my IAP in VC.
  • 1.  SNMP - Help with MIB to monitor the clients of my IAP in VC.
    Posted Jun 29, 2017 05:19 PM
    Dear,
    I need the Instant MIB, I could only find the: ARUBA-MGMT-MIB.mib // ARUBA-MIB.mib // ARUBA-TC.mib this way, I can not follow the connected clients in my ZABBIX via snmp, can anyone help?
    My WLC is an Aruba Virtual Controller (VC).
    aiClientTableEntry
    aiClientMACAddress1.3.6.1.4.1.14823.2.3.3.1.2.4.1.1
    aiClientWlanMACAddress1.3.6.1.4.1.14823.2.3.3.1.2.4.1.2
    aiClientIPAddress1.3.6.1.4.1.14823.2.3.3.1.2.4.1.3
    aiClientAPIPAddress1.3.6.1.4.1.14823.2.3.3.1.2.4.1.4
    aiClientTxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.5
    aiClientTxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.6
    aiClientTxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.7
    aiClientRxDataFrames1.3.6.1.4.1.14823.2.3.3.1.2.4.1.8
    aiClientTxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.9
    aiClientRxRetries1.3.6.1.4.1.14823.2.3.3.1.2.4.1.10
    aiClientTxRate1.3.6.1.4.1.14823.2.3.3.1.2.4.1.11
    aiClientRxDataFrames1.3.6.1.4.1.14823.2.3.3.1.2.4.1.12
    aiClientRxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.13
    aiClientRxRetries1.3.6.1.4.1.14823.2.3.3.1.2.4.1.14
    aiClientRxRate1.3.6.1.4.1.14823.2.3.3.1.2.4.1.15
    aiClientUptime
    1.2.4.1.16
    snmpwalk -v 2c -c snmp + IP
    SNMPv2-MIB::sysDescr.0 = STRING: ArubaOS (MODEL: 103), Version 6.5.2.0-6.5.2.0
    SNMPv2-MIB::sysObjectID.0 = OID: ARUBA-MIB::apProducts.69
    DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (974054) 2:42:20.54
    SNMPv2-MIB::sysContact.0 = STRING:
    SNMPv2-MIB::sysName.0 = STRING: f0:5c:19:cd:17:ac
    SNMPv2-MIB::sysLocation.0 = STRING:
    SNMPv2-MIB::sysServices.0 = INTEGER: 72
    IF-MIB::ifNumber.0 = INTEGER: 6
    IF-MIB::ifIndex.1 = INTEGER: 1
    IF-MIB::ifIndex.50 = INTEGER: 50
    IF-MIB::ifIndex.70 = INTEGER: 70
    IF-MIB::ifIndex.90 = INTEGER: 90
    IF-MIB::ifIndex.91 = INTEGER: 91
    IF-MIB::ifIndex.500 = INTEGER: 500
    IF-MIB::ifDescr.1 = STRING: eth0
    IF-MIB::ifDescr.50 = STRING: radio0_ssid_id0
    IF-MIB::ifDescr.70 = STRING: radio1_ssid_id0
    IF-MIB::ifDescr.90 = STRING: gre0
    IF-MIB::ifDescr.91 = STRING: gre1
    IF-MIB::ifDescr.500 = STRING: BR0
    IF-MIB::ifType.1 = INTEGER: gigabitEthernet(117)
  • 2.  RE: SNMP - Help with MIB to monitor the clients of my IAP in VC.
    Posted Jul 09, 2017 09:29 AM
    Im having the same issue with LibreNMS ...we need the correct OID.
  • 3.  RE: SNMP - Help with MIB to monitor the clients of my IAP in VC.
    Posted Jul 09, 2017 09:49 AM
    Please see the attached MIB reference guide to see what you are looking for.  This guide is no longer published, as the descriptions are in the mibs themselves.
    Attachment(s)
  • 4.  RE: SNMP - Help with MIB to monitor the clients of my IAP in VC.
    Posted Jul 09, 2017 10:18 AM
    Hi Colin,
    Do you know why eth0 and eth1 report bogus SNMP data?
    for example snmpwalk -
    Port eth0: eth0 (1 / #20549) VLAN == ifType eth0bps(834.510Tbps/43.320Tbps)bytes(13.160PB/699.380TB)pkts(164.930Gpps/42.980Gpps)
    any way to fix this?
  • 5.  RE: SNMP - Help with MIB to monitor the clients of my IAP in VC.
    Posted Jul 09, 2017 11:13 AM
    I do not know.  You might want to open a TAC case to get those questions answered.
  • 6.  RE: SNMP - Help with MIB to monitor the clients of my IAP in VC.
    Posted Jul 09, 2017 01:31 PM
    Gentlemen, Even downloading the WLSX MIBS, I can not get the number of users associated with my antenna. Another important point is that the Time and Bytes values are not correct.
  • 7.  RE: SNMP - Help with MIB to monitor the clients of my IAP in VC.
    Posted Jul 11, 2017 09:14 AM
    Gentlemen,
    I used the reference guide as requested (6.2.0.0-3.2), however, I still have no access to snmps calls, and according to the image below, I already have all the mibs on my server, can you help me?
