SNMP OID for get list of neighbor APs from IAP
  • 1.  SNMP OID for get list of neighbor APs from IAP
    Posted Mar 07, 2014 02:30 AM
             I am using an Instant AP in VC mode with Background Scanning enabled on it. I need the list of all the neighbor APs seen by it.
    When I used "wlsrAirMonitorApListTable" to fetch the data using SNMP Poll I get  "No such Object" Error.  On CLI when I type "show ap monitor ap-list" I am able to get the details. I need the same information using SNMP GET. I tried putting the IAP in monitor mode, but still the same SNMP error comes.
    Please guide.
    Tuhin
  • 2.  RE: SNMP OID for get list of neighbor APs from IAP
    Posted Mar 10, 2014 10:25 AM
                     Kindly update, as this information is urgent for me.
    Tuhin
  • 3.  RE: SNMP OID for get list of neighbor APs from IAP
    Posted Mar 11, 2014 03:28 PM
    if you need urgent assistence Aruba support is what you should turn to.
