SNMP OID for Station Phy Type
  • 1.  SNMP OID for Station Phy Type
    Posted Jul 25, 2015 06:34 AM
    I would like to use Cacti to monitor our controllers, in particular I'm trying to create a graph that shows the various client protocols in use (11a/b/g/n/ac etc.) - example from our Cisco WLC:
    Reding throuhg the WLSX-WLAN-MIB it seems the "wlsxWlanStationTable" is what I am after and walking the controller for .1.3.6.1.4.1.14823.2.2.1.5.2.2.1.1.3 (wlanStaPhyType) returns useful data:
    Will-rMBP15:~ williamjones$ snmpwalk -v 2c -c wjcommsSNMP 10.10.1.5 .1.3.6.1.4.1.14823.2.2.1.5.2.2.1.1.3
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.0.187.58.71.155.103 = INTEGER: 1
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.36.36.14.237.168.159 = INTEGER: 3
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.40.207.233.19.122.173 = INTEGER: 1
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.112.62.172.64.229.116 = INTEGER: 3
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.112.222.226.184.51.251 = INTEGER: 1
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.116.194.70.125.249.108 = INTEGER: 3
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.160.11.186.138.134.47 = INTEGER: 1
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.184.23.194.214.77.118 = INTEGER: 1
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.188.146.107.108.133.232 = INTEGER: 1
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.204.250.0.170.69.46 = INTEGER: 1
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.2.1.1.3.204.250.0.243.134.176 = INTEGER: 1
    This is excellent as it is basically the same way we are gathering data for Cisco WLCs at the moment, so adapting our templates for Aruba controllers should be easy, at the moment I think:
    1= 5GHz 11n/ac
    3= 2.4GHz 11n
    Where I could use a bit of help is does anybody have a key to what the different integer values are and what the total range of integers is, I can then count and total these to build an array to give me the graphy I want. :)
    Also, we have AMP running in the lab for eval, does anybody know if such a graph already exists or can be generated by report.
  • 2.  RE: SNMP OID for Station Phy Type
    Posted Jul 26, 2015 10:46 PM
    hello
    if you actually load the mib then snmp will do the work for you:
    root@bt:/home/aruba/mibs/6.4.2.8# snmpwalk -v2c -c public -O0X -mALL -M. 192.168.1.164 wlanStaPhyType
    WLSX-WLAN-MIB::wlanStaPhyType[STRING: 5c:c5:d4:7c:a3:44] = INTEGER: dot11a(1)
    WLSX-WLAN-MIB::wlanStaPhyType[STRING: e8:50:8b:0d:68:0d] = INTEGER: dot11a(1)
    alternatively the answer to your question, more specfically, is in the MIB itself.
    >> from aruba-wlan.my (this is the OID you are getting)
      wlanStaPhyType OBJECT-TYPE
             SYNTAX       ArubaPhyType
             MAX-ACCESS   read-only
             STATUS       current
             DESCRIPTION            "      Type of the Station.            "
            ::= { wlsxWlanStationEntry 3 }
    >> then refer to aruba-tc.my to find out what is ArubaPhyType
    ArubaPhyType ::= TEXTUAL-CONVENTION
      STATUS    current
      DESCRIPTION
          " Represents the PHY-type of the access point or client.  Wired clients will   show 'wired' in user MIB entries.    "
      SYNTAX       INTEGER {
                dot11a(1),
                dot11b(2),
                dot11g(3),
                dot11ag(4),
                wired(5)
    >> and for completeness
    ArubaHTMode ::= TEXTUAL-CONVENTION
      STATUS    current
      DESCRIPTION
          " Represents the HT status of the access point or client.    "
      SYNTAX       INTEGER {
                none(1),
                ht20(2),
                ht40(3),
                vht20(4),
                vht40(5),
                vht80(6),
                vht160(7),
                vht80plus80(8)
    you will need to sum this up for feeding to cacti, but that should be easy enough to do with a shell script attached to cacti, let me know if you need some hints on that.
    regards
    -jeff
