Cloud Managed Networks
SNMP on Switches in Aruba Central
  • 1.  SNMP on Switches in Aruba Central
    Posted Aug 13, 2019 05:27 AM
    How can you configure SNMP parameters for switches in Aruba Central? I can only find it for AP's.
    I'm trying to import my switches in IMC and only when I disable Central management on the switch ("no aruba-central enable"), IMC can read all the information. When I keep Aruba Central enabled, I get a generic device with no extra information (no model, no firmware, no sysname, ...)
    Thanks!
  • 2.  RE: SNMP on Switches in Aruba Central
    Posted Aug 20, 2019 07:12 PM
    you can set it along other CLI commands if the switch is managed by templates. when you create a Group in Aruba Central you can make that group a template based group
  • 3.  RE: SNMP on Switches in Aruba Central
    Posted Aug 21, 2019 04:08 AM
    I tried with a template group, the SNMP settings are pushed but I still get errors in IMC.
    When I turn off switch management via Aruba Central, the error is gone.
    I have a call for this case in 30 minutes, so I will post an update once we have the solution :)
  • 4.  RE: SNMP on Switches in Aruba Central
    Posted Aug 21, 2019 05:04 PM
    from my point of view, the issue is that iMC is doing a lot of things via ssh. But if the Switch is connected to Central most cli commands are not available without enabling support mode
