SNMP Queues
  • 1.  SNMP Queues
    Posted Mar 05, 2012 11:01 AM
    The system logs in my controllers are being overrun with the following message.
    Mar 2 13:07:44 :301268:  <WARN> |snmp|  Reached the limit on Inform Notification queue for 144.30.1.234:162
    Mar 2 13:10:14 :301268:  <WARN> |snmp|  Reached the limit on Inform Notification queue for 144.30.1.234:162
    Mar 2 13:14:10 :301268:  <WARN> |snmp|  Reached the limit on Inform Notification queue for 144.30.1.234:162
    Mar 2 13:16:16 :301268:  <WARN> |snmp|  Reached the limit on Inform Notification queue for 144.30.1.234:162
    I have had a TAC case open for a couple of months to no avail.  Has anyone else seen these messages?
  • 2.  RE: SNMP Queues
    Posted Mar 05, 2012 02:10 PM
    Is 144.30.1.234 your SNMP management server?
    If so, you may have an issue there where it is not processing the info requests in a timely manner.
  • 3.  RE: SNMP Queues
    Posted Mar 05, 2012 02:22 PM
    On the CLI, do the following command - "show snmp inform stats".  Do you see overflows?
    Check the IP Address for the SNMP host.  Are you sure it should be 144.30.1.234?
    Is there anything that would block UDP/162?
    Do you filter at the receiver (only allow certain IP addreses to send informs)?  Make sure you are allowing the correct address to send them to your host.
    Also, as chrisbrizzell said, make sure your receiver is not overloaded.
  • 4.  RE: SNMP Queues
    Posted Mar 05, 2012 03:00 PM
    By default, unacknowledged informs will be sent every 60 seconds for up to 3 times before it is dropped. You can try changing the 60 second interval using the  “interval” attribute in snmp-server host “eg. snmp-server host …. version 3 ….. interval <>”. You can also try changing the number of retries via retrycount attribute in snmp-server config.  “snmp-server host <ip> version 3 <WORD> retrycount “.  After the inform is dropped, the next inform in the queue is processed. If the inform queue is full new informs will not be added in the queue and will be dropped.If the controller is generating excessive traps faster than the trap receiver can acknowledge the traps then the queue will always be full.  You can try disabling some traps or use non-inform v2/v3 hosts or v1 trap host.
  • 5.  RE: SNMP Queues
    Posted Mar 07, 2012 02:34 PM
    Thanks guys it looks like were simply overloading our AirWave Server.  May be time to upgrade.
