SNMP Trap Filter
  • 1.  SNMP Trap Filter
    Posted Apr 11, 2018 10:20 PM
    is it possible to limit the number of SNMP Traps that are being send by the IAP?
    Thank you and best Regards
  • 2.  RE: SNMP Trap Filter
    Posted Apr 12, 2018 08:10 AM
    In controller we have option to disable unwanted traps but in IAP we dont have option.
  • 3.  RE: SNMP Trap Filter
    Posted Apr 12, 2018 08:47 AM
    Hi, Pavan
    Thanks for your reply!
