Hi, I have a MM and MC with firmware version 8.4.0.3. I have enabled SNMP trap for wlsxUserAuthenticationFailed and wlsxNUserAuthenticationFailed. When I run the command : show snmp trap-list, the trap is enabled. However, when I use a wrong username and password to connect to the SSID, it is not generating the trap. When it is connected successfully, the trap is generated when I checked : show snmp trap-queue. What could I need to do to generate the trap? Thanks.
