Is there a cli command on the M3s to disable many traps at once? I only need a few enabled, but seems you would have to disable the ones you don't need one by one.
Thanks!
I see a post below that Cjoseph posted a script to disable all at once (by doing it one by one), I'll use that for now. However, a command to disable "all" (without turning SNMP Traps off) would be nice..
Thanks Cjoseph,
Marcelo
