SNMP Walk Response
  • 1.  SNMP Walk Response
    Posted Dec 03, 2014 03:03 PM
    Given the snmp response below, what are the last 6 octets for, 108.243.127.81.100.208 ?
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.1.7.1.9.108.243.127.205.22.76.1.108.243.127.81.100.208
    These are the examples I am trying to understand:
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.1.7.1.9.108.243.127.205.22.76.1.108.243.127.81.100.208 = Timeticks: (105441100) 12 days, 4:53:31.00
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.1.7.1.9.108.243.127.205.22.76.2.108.243.127.81.100.192 = Timeticks: (105441100) 12 days, 4:53:31.00
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.1.7.1.9.108.243.127.205.22.122.1.108.243.127.81.103.176 = Timeticks: (573872200) 66 days, 10:05:22.00
    SNMPv2-SMI::enterprises.14823.2.2.1.5.2.1.7.1.9.108.243.127.205.22.122.2.108.243.127.81.103.160 = Timeticks: (573872200) 66 days, 10:05:22.00
  • 2.  RE: SNMP Walk Response
    Posted Dec 03, 2014 10:11 PM
    Looks like an (AP-275?) MAC address.  Hexify it.
  • 3.  RE: SNMP Walk Response
    Posted Dec 04, 2014 08:41 AM
    yup correct.
    I have a python script that converts decimal to mac and vice-versa...if you need it PM me
  • 4.  RE: SNMP Walk Response
    Posted Dec 04, 2014 08:49 AM
    Can you give me the values returned to you? I get a different MAC from the wlanAPBssidAPMacAddress SNMP string. 6c:f3:7f:cd:16:4c is what I would expect but the decimal to hex converter I am using disagrees.
  • 5.  RE: SNMP Walk Response
    Posted Dec 04, 2014 04:13 PM
    I underestand from the example I gave that 108.243.127.205.22.76 is the MAC of the radio and the following .1 identifies the radio but the 108.243.127.81.100.208 ending in .14823.2.2.1.5.2.1.7.1.9.108.243.127.205.22.76.1.108.243.127.81.100.208 is my issue.  Is this the wi-fi MAC and the previous .76 is the ethernet MAC? or something else?
  • 6.  RE: SNMP Walk Response
    Posted Dec 05, 2014 02:38 AM
    rs894f
    that is the BSSID uptime, indexed by AP MAC [radio index] with one uptime result per BSSID
    let snmpwalk do the work for you:
    root@kali:/home/aruba/mibs/6.3.1.2# snmpwalk -v2c -c public -mALL -M. -O0X  c7030 .1.3.6.1.4.1.14823.2.2.1.5.2.1.7.1.9
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][1][STRING: 00:24:6c:22:47:88] = Timeticks: (1448700) 4:01:27.00
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][1][STRING: 00:24:6c:22:47:89] = Timeticks: (1448700) 4:01:27.00
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][1][STRING: 00:24:6c:22:47:8a] = Timeticks: (1448700) 4:01:27.00
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][1][STRING: 00:24:6c:22:47:8b] = Timeticks: (1448700) 4:01:27.00
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][2][STRING: 00:24:6c:22:47:80] = Timeticks: (1448700) 4:01:27.00
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][2][STRING: 00:24:6c:22:47:81] = Timeticks: (1448700) 4:01:27.00
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][2][STRING: 00:24:6c:22:47:82] = Timeticks: (1448700) 4:01:27.00
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][2][STRING: 00:24:6c:22:47:83] = Timeticks: (1448700) 4:01:27.00
    where
    -M.           -- get mibs in current dir
    -mALL    -- export all mibs
    -O0X       -- decode hex  with 0 padding (that's OH-ZERO-X)
    regards
    -jeff
  • 7.  RE: SNMP Walk Response
    Posted Jan 06, 2015 03:46 PM
    When you say "AP MAC [radio index]" you are referring to [1] and [2].  Does [1] reference the A radio and [2] reference the b/g radio?  Using your example below:
  • 8.  RE: SNMP Walk Response
    Posted Jan 06, 2015 09:36 PM
    correct, for 2 radio AP, radio 1 = 11a, radio 2 = 11g (for single radio, it will be 1 only, but you would have to find the band via other means if you weren't sure of it). You can also cross check from CLI using "show ap bss-table bssid 00:24:6c:22:47:88" for example.
