SNMPWALKing the VC does not always respond
  • 1.  SNMPWALKing the VC does not always respond
    Posted Aug 08, 2013 01:07 PM
    We have an access controller (developped in-house) to deliver captive portal which is in front of the IAP cluster.
    From this access controller, I cannot snmpwalk directly the VC.
    When I attempt to walk any of the other APs on the network it works, then I try walking the VC and it works.
    After some time, snmpwalking the VC directly stops working.
    The network is designed as such
    Access controller -> Cisco Core Switch -> Aruba S2500 edge switches -> IAP
    Everything is on the same subnet (not my design :) )
    Any ideas?
  • 2.  RE: SNMPWALKing the VC does not always respond
    Posted Sep 19, 2013 11:18 AM
    No responses I guess.
    I am also experiencing the following where it sometimes responds and sometimes does not.
    If a VC would transfer over to another AP, the snmpwalk breaks.
    IAP now version 3.4.0.1
  • 3.  RE: SNMPWALKing the VC does not always respond
    Posted Oct 09, 2013 08:59 AM
    hey pmonardo, I've got a potential bug filed for this within a client deployment. PM me and we can validate your setup as well as the suspected issue.
  • 4.  RE: SNMPWALKing the VC does not always respond
    Posted Oct 09, 2013 09:27 AM
    Sure thing.
  • 5.  RE: SNMPWALKing the VC does not always respond
    Posted Oct 15, 2013 04:02 PM
    Fix has been released in 3.4.0.3.
  • 6.  RE: SNMPWALKing the VC does not always respond
    Posted Jan 16, 2014 02:23 PM
    Not fixed in release 3.4.0.3 and neither in 4.0.0.1.
    Still working on it
  • 7.  RE: SNMPWALKing the VC does not always respond
    Posted Jan 20, 2014 08:18 AM
    Do you have debug level enabled on the iAP's and if soo is there anything that happens everytime the VC stops reposding.
    Do you have SNMP walk the VC IP and the AP IP at the same time and you are not getting replies from either?
  • 8.  RE: SNMPWALKing the VC does not always respond
    Posted Jan 20, 2014 02:19 PM
    I've done the following:
    Taking a pcap at the uplink
    Taking a pcap at the AP
    Enabled SNMP debug on the IAP
    Aruba has identified this as a bug and I am awaiting an answer
  • 9.  RE: SNMPWALKing the VC does not always respond
    Posted Jan 22, 2014 08:28 AM
    I told you what settings I applied on my iAP and I'm still able after 48 hours to get SNMP replies from my VC.
    Tried them out and let us know :)
  • 10.  RE: SNMPWALKing the VC does not always respond
    Posted Jan 22, 2014 08:50 AM
    I tried the same with my IAP and it does not work.
    Again, Aruba has filled a bug and was able to replicate it.
  • 11.  RE: SNMPWALKing the VC does not always respond
    Posted Feb 18, 2014 09:25 AM
    Do you have any update on this? I have the same problem, I can poll the the IAPs one-by-one, but not the VC IP address.
  • 12.  RE: SNMPWALKing the VC does not always respond
    Posted Feb 18, 2014 09:27 AM
    No update as of yet.
    Which version did you test?
  • 13.  RE: SNMPWALKing the VC does not always respond
    Posted Feb 18, 2014 09:30 AM
    hello,
    we are on 6.3.1.2-4.0.0.3_41784, all access points are IAP-225.
    regards,
    Mark Szabo
  • 14.  RE: SNMPWALKing the VC does not always respond
    Posted Feb 18, 2014 09:41 AM
    if i query an AP directly this is what i get is pretty unusable, most of the counters are showing 0 (SNR, Rate, Retries) even polling multiple times.
    this has nothing to do with snmp, it's just one more thing not working, but i am really unhappy with this whole instant solution, nothing works as it should. we had serious packet loss, disconnects, we had to disable client match, 80 mhz channels, etc. its full of bugs and looks like we are beta testers.
    # snmpwalk -M /root/mibs:/var/lib/mibs/iana:/var/lib/mibs/ietf -m ARUBA-MIB:AI-AP-MIB -v2c -c public 10.220.9.119 aiClientTable | grep '.....Y'
    AI-AP-MIB::aiClientMACAddress.'.....Y' = STRING: b0:5:94:92:b7:59
    AI-AP-MIB::aiClientWlanMACAddress.'.....Y' = STRING: 18:64:72:e3:b0:1
    AI-AP-MIB::aiClientIPAddress.'.....Y' = IpAddress: 10.220.9.189
    AI-AP-MIB::aiClientAPIPAddress.'.....Y' = IpAddress: 10.220.9.119
    AI-AP-MIB::aiClientName.'.....Y' = STRING:
    AI-AP-MIB::aiClientOperatingSystem.'.....Y' = STRING: Win 7
    AI-AP-MIB::aiClientSNR.'.....Y' = INTEGER: 0
    AI-AP-MIB::aiClientTxDataFrames.'.....Y' = Counter32: 0
    AI-AP-MIB::aiClientTxDataBytes.'.....Y' = Counter32: 0
    AI-AP-MIB::aiClientTxRetries.'.....Y' = Counter32: 0
    AI-AP-MIB::aiClientTxRate.'.....Y' = INTEGER: 0
    AI-AP-MIB::aiClientRxDataFrames.'.....Y' = Counter32: 0
    AI-AP-MIB::aiClientRxDataBytes.'.....Y' = Counter32: 0
    AI-AP-MIB::aiClientRxRetries.'.....Y' = Counter32: 0
    AI-AP-MIB::aiClientRxRate.'.....Y' = INTEGER: 0
    AI-AP-MIB::aiClientUptime.'.....Y' = Timeticks: (0) 0:00:00.00
  • 15.  RE: SNMPWALKing the VC does not always respond
    Posted Feb 18, 2014 09:45 AM
    Have you opened cases with TAC to resolve your issues? Solution will only get better if TAC is aware so they can trigger proper personnel.
    have you tried a simple SNMPWALK and see what you get?
    snmpwalk -c <community> -v 2c <IAP IP>
    I am using the same IAP version as well I haven't had those issues. Not with 225's though.
  • 16.  RE: SNMPWALKing the VC does not always respond
    Posted Feb 18, 2014 09:55 AM
    we have tac case open with the packet loss, connectivity problems, client match, etc issues. the snmp issue is new for me, we do not have tac case about that yet. i will proceed with opening a case. but as i understand you have problems with snmp as well, filled a bug, aruba could reproduce and you are waiting for the solution.
    i can snmpwalk the 9 accesspoint we have, but not the virtual controller. the virtual controller ip address does not respond to snmp queries.
    if i snmpwalk the individual accesspoints i got information only about the specific access point. for example aiClientTable only contains the clients connected to the queried access point.
  • 17.  RE: SNMPWALKing the VC does not always respond
    Posted Feb 21, 2014 08:08 AM
    This issue is addressed in IAP 4.1 which is forthcoming shortly. Thanks to pmonardo for helping isolate the issue with Dev/Eng at Aruba.
    Adam
  • 18.  RE: SNMPWALKing the VC does not always respond
    Posted Jun 26, 2014 09:22 PM
    I can officially confirm IAP 4.1 allows SNMPwalk to the VC
