Network Management
  • 1.  Software:The version could not be evaluated
    Posted Sep 27, 2021 03:21 AM
    Dears,
    Using iMC or downloading from the HP download center, all Firmwares come in .ZIP format. Inside the .bin have 2 files which are a "freeradius" and a "packet-capture". files.
    Which one should I choose? Because the old files are not like this and seem. Problem also is that I can't find that format anymore.
    IMC can only accept .BIN files to be able to evaluate the software and therefore you can proceed to the next step.
    Thanks for the support.
    #imc
    #zip
    #firmware
  • 2.  RE: Software:The version could not be evaluated
    Posted Sep 27, 2021 04:24 AM
    Hello @Waverunner ,
    From which version to which version are you upgrading?
    Can you share the product number 'JXXXXXX'?
    Thanks!
  • 3.  RE: Software:The version could not be evaluated
    Posted Sep 27, 2021 04:27 AM
    Upgrading from 7.1.070 Release 3506P11    to     5130_EI_7.10.R3506P11.zip
    My Switch is a JG936A.
  • 4.  RE: Software:The version could not be evaluated
    Posted Sep 27, 2021 05:14 AM
    Hello @Waverunner ,
    From topic heading it seems IMC issue however this is a switch issue.
    I am not sure how oyu will upgrade 'from' to 'to' on same version. "Upgrading from 7.1.070 Release 3506P11    to     5130_EI_7.10.R3506P11.zip"
    --Above both are same versions.
    However below is the link for latest software version: 5130_EI_7.10.R3507
    https://h10145.www1.hpe.com/downloads/DownloadSoftware.aspx?SoftwareReleaseUId=29716&ProductNumber=JG936A&lang=&cc=&prodSeriesId=&SaidNumber=
    Below is the link for latest software version: 5130_EI_7.10.R3506P11
    https://h10145.www1.hpe.com/downloads/DownloadSoftware.aspx?SoftwareReleaseUId=28916&ProductNumber=JG936A&lang=&cc=&prodSeriesId=&SaidNumber=
    Inside .zip file you will get .ipe or .bin file.
    Thanks!
  • 5.  RE: Software:The version could not be evaluated
    Posted Sep 27, 2021 05:45 AM
    Thanks akg7,
    I misspelled worng the firmwares on the chat.
    Thanks for sharing the links but I was more looking for the reply I got from Ivan_B
    It really answered my question.
    Thank you all
  • 6.  RE: Software:The version could not be evaluated
    Posted Sep 27, 2021 05:21 AM
    Hi @Waverunner !
    For the software update you will need only .IPE file (like '5130EI-CMW710-R3507.ipe').
    'packet-capture.bin' is the hot-patch that enables packet capture and analysis on the switch itself. It is necessary patch if you plan to use 'packet-capture' command, but since this feature is used primarily during troubleshotting phase and is not needed during normal operation, HPE decided to separate this functionality from the main software.
    'freeradius' is a feature image, again installed as a hot-patch that adds FreeRADIUS functionality to a switch when it works as a RADIUS server. Again, since it's a corner case, this feature is separated from the main image.
  • 7.  RE: Software:The version could not be evaluated
    Posted Sep 27, 2021 05:46 AM
    Thanks Ivan,
    This was a answer that I was lookign for.
    Best regards
