Solarwinds SCP server to Controller issues.
  • 1.  Solarwinds SCP server to Controller issues.
    Posted Oct 21, 2020 01:24 PM
    I am attempting to copy a file to a 6.4 controller via command line and using solarwinds scp server. I can copy files from the controller without issue but for the love of all that is holy I cant figure out what I am doing wrong.
    Here is the command.
    10.10.10.10 windows 2012 server running Solarwinds SCP server.
    Username of "Aruba"
    Excuted on local controller running 6.4.4.21 FIPS
    #copy scp 10.10.10.10 Aruba md_setup.cfg flash: md_setup.cfg
    Password:*********
    Secure File Copy:....
    Error downloading file
    scp: Failed to open file md_setup.cfg.
    The SCP server shows.
     10/21/2020 11:15 AMUnknownAuthenticated user Aruba from IP 10.11.10.25.
     10/21/2020 11:15 AMUnknownUser Aruba from IP 10.11.10.25 downloading file at "md_setup.cfg".
    I have tried forward and back slashes, putting the file in a folder and adding the path both with and without the drive. If I reverse the order I can download a file from the controller without issue. I also tried via the GUI without luck.
    Any help would make my day.
    Thank You,
  • 2.  RE: Solarwinds SCP server to Controller issues.
    MVP EXPERT
    Posted Oct 21, 2020 01:32 PM
    Hi Hargert,
    Iam not familar with Solarwinds SCP. But i write a blog howto quickly setup a SCP server in 3 minutes based on a free Turnkey Linux fileserver runs on VMware. https://blog.marcelkoedijk.nl/?p=54
    Another suggestion is test your SCP server with a client like WINSCP and look if its good configured.
    Maybe it helps.
  • 3.  RE: Solarwinds SCP server to Controller issues.
    Posted Oct 21, 2020 01:36 PM
    I am not using the FIPS version but this works as long as I configure the root directory correct in solarwinds scp server on Windows 10
    (Babarella) #copy scp: 192.168.1.207 admin ArubaOS_72xx_8.5.0.0-2.0.0.6_76205 flash: ArubaOS_72xx_8.5.0.0-2.0.0
    Password:**********
    Press 'q' to abort.
    Secure File Copy:........................................................................................................................................................................................................................................................................................................
    File Copied Successfully!
  • 4.  RE: Solarwinds SCP server to Controller issues.
    Posted Oct 21, 2020 01:56 PM
    I just tried with a larger file and it transferred as expected so it looks like an issue with the file I am trying to send. Thank you very much for the help!
