Network Management
Solution to monitor power supply modules of Aruba switches
This thread has been viewed 33 times
  • 1.  Solution to monitor power supply modules of Aruba switches
    Posted Jan 24, 2022 02:24 PM
    Hey There,
    I have been looking for a solid solution which is able to monitor power supply status of Aruba switches, not power consumption, but something like PS online, PS failed or PS not inserted, etc. I've known that NAE component can do this but only for AOS-CX based switches like 6200 or above. Is there a total solution that can monitor other switch models like 2930 and 5400?
    Thank you in advance.
    Lejian Wang
  • 2.  RE: Solution to monitor power supply modules of Aruba switches
    Posted Feb 08, 2022 04:47 AM
    You can use Airwave Management solution to achieve your requirements.
    Pavan Arshewar
    Principal Network Engineer
    If my post addresses your query, give kudos!
  • 3.  RE: Solution to monitor power supply modules of Aruba switches
    Posted Feb 08, 2022 11:23 AM
    Hey Pavan,
    Would you please elaborate a little bit more on which part of Airwave that provides the option? As when I searched for power supply throughout the entire Airwave guide, I could only find power consumption monitor, but nowhere found the power supply status monitor.
    Lejian Wang
  • 4.  RE: Solution to monitor power supply modules of Aruba switches
    Posted Feb 09, 2022 05:32 PM
    I don't know about solutions that gather this info, but I've found the power supply status available in SNMP.  The entries for POWERSUPPLY-MIB::hpicfPsState
    HpicfDcPsState ::= TEXTUAL-CONVENTION
        STATUS        current
        DESCRIPTION   "An enumerated value which provides the state of the
                      switch power supply entity."
        SYNTAX        INTEGER  {
           psNotPresent(1),
           psNotPlugged(2),
           psPowered(3),
           psFailed(4),
           psPermFailure(5),
           psMax(6)
    I have been able to use this OID for 2920s (stacked), 2930Ms (stacked), 5406Rzl2 (stacked and unstacked).  Here are some outputs I gathered when testing.
    2920 stack of 4 (1 PSU each)
    POWERSUPPLY-MIB::hpicfPsState.1 = INTEGER: psPowered(3)
    POWERSUPPLY-MIB::hpicfPsState.2 = INTEGER: psPowered(3)
    POWERSUPPLY-MIB::hpicfPsState.3 = INTEGER: psPowered(3)
    POWERSUPPLY-MIB::hpicfPsState.4 = INTEGER: psPowered(3)
    2930M stack of 2 (2 PSU each)
    POWERSUPPLY-MIB::hpicfPsState.5 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.6 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.7 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.8 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.9 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.10 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.11 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.12 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.13 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.14 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.15 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.16 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.17 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.18 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.19 = INTEGER: psNotPresent(1)
    POWERSUPPLY-MIB::hpicfPsState.20 = INTEGER: psNotPresent(1)
    5406Rzl2 vsf stack of 2 (2 PSU each)
    Andrew Lowther
