I need to authorize user with ad account can connect to the wifi. ClearPass can join my active directory but i want , when the user select the SSID, i want the user put the credentials of his account for to connect to the wifi.
Regards
You'll need to add AD as an Authentication Source.
https://www.arubanetworks.com/techdocs/ClearPass/Aruba_DeployGd_HTML/Content/Active%20Directory/AD_auth_source_adding.htm
What authentication method (e.g EAP-PEAP) are you planning to use in your environment? You would specify your authentication method method as part of the service and if required configure the end client accordingly.
since you want the users to type in their AD credentials, make sure you have AD as your auth source and use EAP-PEAP as the auth method.
Yes, it's okey now.
I'm sorry for my late, i'm in intership not always in the compagny.
Thank you for your help
