Some 5Ghz Channels not available on IAP-305
  • 1.  Some 5Ghz Channels not available on IAP-305
    Posted Apr 14, 2017 06:37 PM
    Hi there, I have noticed that the following channels are not available on a IAP-305(RW)
    149
    153
    157
    161
    165
    These are available on a IAP-205(RW) in the same cluster.
    I have tried updatig the lates 6.5.2.0 firmware and no change.
    Any reason why?
  • 2.  RE: Some 5Ghz Channels not available on IAP-305
    Posted Apr 14, 2017 06:48 PM
    What country code did you set the cluster to?
  • 3.  RE: Some 5Ghz Channels not available on IAP-305
    Posted Apr 14, 2017 07:31 PM
    NZ - New Zealand
    Kind regards,
    Nick Perry | Senior Systems Engineer
    --REPLY above this line to respond (Internal Only)--
    [cid:image85a752.PNG@3cb538d7.40aefd96]
    P +64 9 916 1180 W www.IT360.co.nz
    Level 5, 205 Wairau Road, Wairau Valley, Auckland, 0627 NZ
    The contents of this message and all attachments have been sent in confidence for the attention of the addressee only
  • 4.  RE: Some 5Ghz Channels not available on IAP-305
    Posted Apr 14, 2017 07:50 PM
    Looks like those UNII3 channels are not approved on the 305 for NZ yet. Future regulatory updates will likely occur to enable those.
  • 5.  RE: Some 5Ghz Channels not available on IAP-305
    Posted Apr 14, 2017 08:48 PM
    Thanks Jerrod, I wondered if that was the case
  • 6.  RE: Some 5Ghz Channels not available on IAP-305
    Posted Apr 15, 2017 11:12 AM
    Just a quick followup, the 305 was one of the first new products to go through the combined HPE/Aruba regulatory process and some paperwork got missed. It's getting completed and at some point those will be added back to the 30x platform accordingly. Our apologies.
  • 7.  RE: Some 5Ghz Channels not available on IAP-305
    Posted Apr 15, 2017 02:32 PM
    Ok thanks for that, good to hear
