some AP are keeping disconnecting and connecting users
  • 1.  some AP are keeping disconnecting and connecting users
    Posted Aug 08, 2017 06:04 AM
    I have 140 AP (100 x 93H + 40 x 105) when enabling high throughput around 25 (93H AP ) are keeps disconnecting and connecting users! but the other are normal, the user is getting the IP but AP disconnect immediately.
    before I enabled high throughput feature, it was normal .
    I have controller 7210 V 6.5.1.3
    thank you in advance :)
  • 2.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 08, 2017 07:18 AM
    If you have high throughput off the whole time, is there a reason why you are enabling it?
  • 3.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 09, 2017 03:05 AM
    Hi Colin,
    thank you for your reply..
    I have hotel environment with 200mbps speed, when disabling hight throughput the bandwidth usage doesnt exceed 80mbps which is weird. after activating it, the usage went double or more.
  • 4.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 09, 2017 07:01 AM
    When you enable HT, do you see any access points have channels like 1+ or 11- ?
  • 5.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 09, 2017 08:19 AM
    yes, ther are some AP +1 & -11
  • 6.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 09, 2017 08:34 AM
    That means you are bonding channels on the 2.4ghz band and that is causing more interference.  You need edit your AP group, go to RF Management> 802.11g radio> Adaptive Radio Management.  Make sure that "Allowed bands for 40MHz channels" is set to "none" and click on apply.
  • 7.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 09, 2017 09:44 AM
    Hi  Colin,
    Ive applied these settings, but still the same
  • 8.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 09, 2017 10:10 AM
    Do the channels still show + and -?
  • 9.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 09, 2017 11:36 AM
    Dear Colin,
    no, ther is no +-
  • 10.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 09, 2017 11:58 AM
    Do you have "Drop Broadcast and Unknown Multicast" enabled on all of your Virtual APs?
  • 11.  RE: some AP are keeping disconnecting and connecting users
    Posted Aug 10, 2017 05:56 AM
    thank you Colin,
    it solved but took time to apply :)
