some AP175P units (3) Only turning on via Poe injector:Midspan 9001G and PowerDsine 3001
  • 1.  some AP175P units (3) Only turning on via Poe injector:Midspan 9001G and PowerDsine 3001
    Posted Mar 03, 2013 06:19 AM
    Hi Guys,
    I have a wired wired problem.
    I got 3 AP-175P units that seems to getting POE only from Midspan 9001G or PD 3001.. :smileysad:
    When i try to connect it to Aruba S3500 or Midspan 9001GO - the unit doesn't turning on at all.
    NOTE:
    • Midspan 9001G
    • Midspan 9001GO
    • PD 3001
    • Arubs S3500
    are working just fine :smileyfrustrated: They are turning on other AP-175P units. And other AP-105 / AP-104 / and all other modules.Of Aruba AP so..The injectors and the switch are just fine.
    Anyone can explain me why? Or what might do that? - is the three units of the AP-175P that i got need to do RTF OR RMA process? If they don't turning on from 802.3af/802.3at standard devices? And only getting ON from 9001G/3001... Wired..
    i hope that someone here in this gr8 forum - already counter such an issue.
    Have a lovely week.
    Me
  • 2.  RE: some AP175P units (3) Only turning on via Poe injector:Midspan 9001G and PowerDsine 3001
    Posted Mar 23, 2013 11:17 AM
    I hate to tell you, but short of changing cables and trying other hardware, you may want to call TAC and get a case opened. I'm assuming you have the POE profile configured on the 3500, not sure about the 9001GO, that should just fire up. Sounds like TAC is your next step. Sorry man...
