I'm working with a ~ 1,250 ap225's backended with pair of 7240's and we're running 6.5.3.5. The ap's are deployed in a high density deployment in a number of schools. The schools are interconnected at 10GB - while their different "sites" they're connected more like they were local buildings bandwidth wise. I'm working on making some modifications to address co-channel interference there have been some connectivity challenges and while ARM can address manythings, it's not magic. Some of these are pretty simple changes such as switching from 80mhz to 40mhz channel bonding which fixed some issues, and good or bad, I'm switching some of the 2.4ghz radio's to air-monitor mode - there's just too many of them and until we can migrate to something like AP345's, we'll have to make other adjustments.
I have multiple ap-groups and I've created a copy of each primary ap-group and simply renamed it, and changed which dot11g-radio-profile is used for the new group.
The challenge I'm running into is that when I move some ap's into one of these new groups, in some instances they are ending up with a Dirty or no config flag set.
It would make sense if this were happening for all ap's being placed into one of these ap-groups, but this seems to affect some ap's only. For example, in a small building I regrouped 5 ap's into the new group - 4 worked fine, one is "dirty". For a much larger building I moved ~ 42 ap's into a different new group, 6 came up dirty.
I've noticed that if I move the ap's marked dirty back into their old group, they go back to a happy state.
I've been searching, and seen some much older posts about this sort of stuff, but nothing recent.
When I look at profile-error's, there is an AAA profile error for teh default profile.
I'd found a show ap debug command, but that was apparently depreciated and wouldn't work in our code revision.
I probably should open a TAC case... but wondered if someone might have some simple suggestions that would point to a solution.
(Thus far I've switched to using ap-name specific device configurations for the ap's I want to adjust in this fashion... but I suspect there's a larger problem here)
