Some clients get 0.0.0.0 ip ?
  • 1.  Some clients get 0.0.0.0 ip ?
    Posted Dec 23, 2014 06:42 AM
    Hi All,
    We have a company which we placed 4 iap 103s. when i check clients on the controllers web gui, i see some clients are getting 0.0.0.0 ip address. It can be a smartphone or a laptop or a pda. when i restart the device ( phone or pda or comp.)   1 times or twice the problem get solved but this happens everyday. I saw someone had the same problem and he deleted and re config it. I tried, that doesn't work for me. Can someone help me ?
    version of iap 103:  6.4.0.2 - 4.1.0.0
    Best Regards.
  • 2.  RE: Some clients get 0.0.0.0 ip ?
    Posted Dec 23, 2014 07:33 AM
    Hi friend,
    Some times WebUI will take some time to refresh the output. to get the accurate output use CLI.
    you can use " show clients" command to get the required output.
    Hope this will help you to get more clarity.
    please feel free for any further query on this.
  • 3.  RE: Some clients get 0.0.0.0 ip ?
    Posted Dec 23, 2014 08:44 AM
    Hi friend i think it is not about latency on web gui. Because when i reboot pda or computer problem ends
  • 4.  RE: Some clients get 0.0.0.0 ip ?
    Posted Dec 28, 2014 12:48 PM
    the question is, what does the client itself say? does it also show 0.0.0.0 or something different?
