Security Training
Some doubts about CPPM certificates
This thread has been viewed 29 times
  • 1.  Some doubts about CPPM certificates
    Posted Apr 12, 2023 02:26 AM
    Hi experts,
    Some of my certificates are going to expire and I have these doubts:
    1. The Radius Server certificate is going to expire. We are using a CPPM self-signed certificate, so I am going to create a new one. When installing this new one Radius certificate, does CPPM need reboot? Does CPPM restart services? Will my users have an impact?
    2. My RadSec Server certificate is going to expire too. If I am not using controllers I can ignore this certificate, right?
    Many thanks in advance.
    Julian
  • 2.  RE: Some doubts about CPPM certificates
    Posted Apr 12, 2023 04:34 AM
    For RADIUS, don't use a self-signed certificate. A private CA issued certificate is fine, but clients will need to validate the RADIUS certificate against a trusted root (as mentioned private root CA is fine for that).
    If you currently really have a self-signed certificate for RADIUS, expect to reconfigure all of your clients as those will not trust the new RADIUS certificate. Some people still disable the server certificate validation in their clients, which brings risks to man-in-the-middle attacks or password attacks. How do you manage/configure your clients?
    The replacement of the RADIUS certificate itself is seamless. There may be a few second outage of the ClearPass RADIUS process, but I never noticed that, so it is probably really short.
    For RadSec, I think the message of an expired certificate is annoying, and you could install the RADIUS certificate for RadSec as well to get the warning cleared. But in theory, you could ignore the expiration.
  • 3.  RE: Some doubts about CPPM certificates
    Posted Apr 12, 2023 07:08 AM
    Hi Herman,
    Why not a self-signed certificate? Because of the warning? And yes, the clients currrently don't validate the certificate.
    Julian
  • 4.  RE: Some doubts about CPPM certificates
    Posted Apr 12, 2023 08:38 AM
    With self-signed certificates on RADIUS, you can't properly validate the certificate against a root CA, and with 'don't validate' your should not ever deploy a network unless you don't care about any security and don't care about the PEAP usernames and passwords leaking out to anyone asking for it.
    Many Apple devices in such a case remembered the current certificate and will not connect, or prompt the user to accept the new certificate if you are lucky.
    My advice: don't use self-signed certificates for EAP, never disable certificate validation; and make sure that you properly configure your certificates and clients.
